RE: Auto Bibel! Sehr interessant!
Absolute Zustimmung, sehr gute Zusammenstellung mit liebevoll erstellten Bildern.
Sogar eine Priese Humor wurde eingestreut.
http://www.carbibles.com/images/brakewarning1.jpg
Most cars nowadays have a brake warning light on the dash. Its purpose is to alert you that something is wrong in the braking system somewhere. If it comes on, check your owner's manual to find out its meaning. Unlike the single-purpose ABS warning light, the brake warning light doesn't have a standard meaning; it could be used for multiple purposes. For example, the same light may be used to show that the hand brake (parking brake for the Americans amongst you) is on. If that's the case and you're driving, you ought to have noticed the smell of burning brake dust by now. The light can also indicate that the fluid in the master cylinder is low. Each manufacturer has a different use and standard for this light. Which is nice. Because it would be such a drag if the same indicator meant the same thing in every vehicle.
http://www.carbibles.com/images/brakewarning2.jpg
If you've got an ABS-equipped car, you also have a second light - the ABS light. If it comes on, get it seen to as soon as possible. It means the ABS computer has diagnosed that something is amiss in the system. It could be something as simple as dirt in one of the sensors, or something as costly as an entire ABS unit replacement. Either way, if that light is on, then you, my friend, have got 1970's brakes. It's important to note that this light normally comes on when you start the car and then switches off a few seconds later. If it stays on, blinks, throbs, flashes or in any other way draws your attention to itself, take note. It's not doing it just to please itself.
http://www.carbibles.com/images/brakewarning3.jpg
If you see this light on your dashboard, then congratulations - you're flying the service module on an Apollo mission. The bad news is that you've got a current drain somewhere and your main batteries are critically low. Either way, drop me a line and let me know how you snagged a seat on a spaceflight - I'm dying to know.
