Ergebnis 1 bis 8 von 8
    ATE Bremsscheiben Und ATE Beläge Für NA Erfahrungen?
    Shoe Shopping Confusing You? These Shoe Tips Can Help
    It can be difficult to fill your closet has contains plenty of attractive and comfortable shoes.The following article will get you started on your learning journey.
    Never wear sneakers without putting on a pair of socks first. This can cause blisters or other sores on your foot since it makes it rub the shoes directly. This will also make foot fungus since the foot is in a shoe getting moist. Wear some dry socks made of cotton to keep feet dry.
    Many people have one foot that is a bit larger or longer than the other. You need shoes fit both feet before you purchase them Ultimate Guide on How To Choose The Best Shoes For Retail Workers Wet the bottom of your feet and step down on white paper. The parts that are wet areas will reveal your arch looks like. This will help you find a shoe that fit.
    A good pair of shoes will be comfortable right away. Breaking new shoes in can actually create problems for your feet.
    Get a pair of sports shoes.If you exercise, walk, run or even play golf, you need shoes that can be worn during these activities. They are there to fit your feet well. Shoes that were not created for certain activities won't support will lead to injuries or painful conditions.
    Always check the return policy before buying shoes online.See if they have a money back guarantee so you don't get stuck with something you cannot wear.
    Buy a pair which ties and one that doesn't to help you in the morning.
    This allows growth room without getting a shoe being too big. Ask the staff at the store for your little one.
    Build a shoe collection so you variety to match with different outfits. You will get good results if you can coordinate your shoes with your outfit.
    Be certain to hold off until it's later in the day when you're shoe shopping. Feet tend to swell as the day. Plan your next shoe shopping trip towards the afternoon. This ensures that your shoes will fit throughout the day.
    Make sure you waterproof shoes that are made of leather shoes. Take care of your shoes so they last much longer.
    A black Sharpie can be a quick fix for a scuffed black leather shoe. This will allow the shoe black rather than appearing as a lighter scuffed area.
    Invest in a nice pair of dress shoes you do not have to suffer through wearing patent leather shoes.You will then be able to avoid painful feet by avoiding those rental shoes.
    Look around for inserts that fit high heels. Doing this can make your favorite shoes a more comfortable experience and can keep your toes from getting hurt.
    Do some searching online to make sure that cute new pair of shoes. You can often find that same shoes for a better deal. This way you'll be able to get the shoes you're wanting for a lower price.
    It is not easy to acquire a collection of shoes that all of your friends will envy. Getting shoes that you love at great prices is a type of art, however you can master it. Use the tips above, and you're going to be a shoe pro.
    Geändert von ariekazy (11.04.2018 um 23:50 Uhr)
    Danke Dank erhalten 613 in 449 Posts  Bedankt 963
    Habe ich seit August auf der Anni, besser als die ganzen Experimente vorher
    Avatar von pit von DO
    bVbStadt
    Zitat Zitat von ariekazy Beitrag anzeigen
    Ich möchte auf die grössere Bremse (255mm)umrüsten, dabei bin ich auf ATE gestoßen. Guter Name! Hat einer Erfahrung mit der Kombi ATE Serienscheibe und ATE Beläge?
    Art.Nr. 24.0120-0169.1
    und 13.0460-5834.2
    Danke für eure Antwort
    John
    Sehr zu empfehlen!
    Nimm die Ceramicbeläge, die sauen nicht ganz so arg rum!
    Außerdem könntest Du schauen, ob es die Scheibe mittlerweile als Powerdisc gibt, die ist mMn noch besser!
    Mal NRW, mal München.
    Zitat Zitat von pit von DO Beitrag anzeigen
    Sehr zu empfehlen!
    Laut ATE-Online-Katalog gibt es weder für den von mir gerade angetesten NA mit 255er-Bremse noch für
    die Sportive-Bremse irgendwelche Ceramic-/Powerdisc-Komponenten.
    Aus Interesse habe ich auch mal meinen X5 eingegeben: für diesen werden normale und Ceramic-Beläge angezeigt.
    Bei den Ceramic-Belägen steht dann noch der Hinweis, dass diese für den Komfort-orientierten Fahrer ausgelegt sind
    und bei zulässiger Verwendung mit Powerdiscs aber laut werden können.
    MX-5 Classic
    Habe bei mehreren Fahrzeugen nur positive Erfahrungen mit ATE gemacht, vor allen Dingen auch mit den Powerdiscs, diese sollte man, auch laut ATE, aber nicht mit den Ceramic Klötzen fahren. Also wenn Ceramic Beläge dann die normalen Bremsscheiben, oder eben die Powerdisc mit normalen Klötzen, der entstehende Bremsstaub wird dann tatsächlich sehr gut abgeführt.
    Avatar von Chrystalwhite
    Norden !
    Eventuell wäre es noch gut, wenn dieser Thread in das NA-Unterforum verschoben werden würde.
    Kwietsch
    Seit ich auf dem Focus Kombi ATE komplett fahre, gibt es keine Probleme mehr. Noch besser: Seit HINTEN (nur da) die Power Disc drauf ist, hab ich keine Probleme mehr mit schlechtem Tragbild oder mies funktionierender Handbremse.
    Auf den MXen gab es zuletzt auch nur noch ATE oder TRW für Straßeneinsatz. Oder eben Carbone Lorraine RC6/RC5E und Tarox G88, wenn es für die NoS gedacht war.
    bVbStadt
    Zitat - Quelle: ATE-Online-Katalog
    Technische Information:
    Es ist technisch möglich, ATE Ceramic Bremsbeläge mit der Po
    werDisc oder mit gelochten Bremsscheiben zu kombinieren.
    Die Bremsleistung bleibt bei dieser Paarung gleich hoch, wie
    bei einem ATE Original- oder OE-Bremsbelag.
    Das Zusammenspiel der beiden Bauteile kann aber zu einer erh
    öhten Geräuschentwicklung beim Bremsvorgang führen.
    ATE Ceramic Bremsbeläge sind Beläge, die für den komfortorie
    ntierten Fahrer entwickelt wurden.
    Grundsätzlich empfehlen wir ATE Ceramic Bremsbeläge daher mi
    t normalen , das heißt glatten Bremsscheiben zu kombinieren.
    Ergo:
    Klar darfst Du die kombinieren!
    Aber die machen dann richtig Krach! Allerdinx nur bei "Hochgeschwindigkeitsbremsungen"
    Bsp.:
    A1 Ausfahrt Schwerte aus Richtung Köln. Da ist freies Jagen und wenn ich mit 220Tacho in die Abbremsspur fahre und
    dann den Anker werfe, fangen einfache Gemüter an zu beten....
  1. [NB⁄NBFL] NBFL Welche Bremsscheiben/Klötze? ATE oder Bosch oder ?
    Von bikeduck im Forum Technik Serie
    Letzter Beitrag: 12.05.2015, 12:48
  2. ATE Bremsscheiben und ATE Beläge für NA Erfahrungen?
    Von coupe54 im Forum Technik Serie
    Letzter Beitrag: 27.08.2013, 16:33
  3. suche für 98er 1,9er NB gute Beläge für Zimmermann-Bremsscheiben
    Von Marc_C im Forum Performance und Tuning
    Letzter Beitrag: 29.08.2005, 10:38
  4. Bremsscheiben und Beläge NA 1,9
    Von Michel im Forum Technik Serie
    Letzter Beitrag: 25.06.2001, 22:28
