Ergebnis 1 bis 4 von 4
    2000 MX5 NB - Replacement Motor - Too Expensive?
    I am an American in Germany. The motor in my 2000 MX5 needs to be replaced but the mechanic is telling me that the motor he found with 130,000km costs approximately EUR 1800. This seems quite expensive, as I am able to locate many motors on Ebay for anywhere between EUR 500 and EUR 1200 depending on the kilometers driven. He now tells me that the motors that I have located will not fit because they are not the same motor code as my MX5 motor. I thought that the motor code was B6, but I might be wrong. How can I determine the motor code when the car is sitting at the garage? I have the Fahtzeugschein on my phone, so the VIN number, etc. is available.
    D-48431
    The cheapest way would be to buy a complete car and sell the parts you don't need. This gives you also the opportunity to drive the car and get an idea in what shape the motor is. You will find cars with rust at rockers and side member but technically in good shape for about 1200 to 1800€.
    D-50674
    Edit, wrong information.
    your car, is it a German NB with the 1.6 engine and 110PS?
    On ebay.de, the most expensive engine is 1699€.
    Is your mechanic trustworthy?
    Does not seem so.
    You can use any 1.6 engine from an NB or NB-FL.
    In my opinion, a friend could sell you an engine for 500€, professional sellers might charge you 850 but 1800, there's the German word "Arschgeige".
    I will send you a PN.
    Do what thou wilt.
  1. NC, klackernder Motor ab 2000 U/Min.
    Von MX283 im Forum Technik Serie
    Letzter Beitrag: 13.12.2009, 11:56
  2. MX-5 NB 1.6 BJ 2000 70000 km Motor springt nicht mehr an
    Von Sebastian323 im Forum Technik Serie
    Letzter Beitrag: 11.01.2006, 18:45
  3. [NB⁄NBFL] NB 2000 motor im Na 1991
    Von cyrus81 im Forum Technik Serie
    Antworten: 22
    Letzter Beitrag: 24.11.2005, 21:25
  4. Motor stottert bei 2000 Umin. :-(
    Von Joerg im Forum Technik Serie
    Letzter Beitrag: 01.06.2001, 12:28
Stichworte
